Aktuelle Zeit: Mi 1. Jul 2026, 02:45
Dichtmittelfragen untenrum..
Beitrag Dichtmittelfragen untenrum..
hola,
Ich habe zwecks Wechsel auf die steifere Oil Rail u.A. den Ölpumpenschnorchel abgebaut; wechselt der engangierte Schrauber dessen Gummidichtring oder schenkt ihr euch das?
Und, Loctite 510 scheint für die Dichtflächen zwischen Oil Rail & Block sowie der Ölwanne gut geeignet zu sein?
merci im Voraus,
Linus
2000er F, derzeit kein HGF
Sa 22. Okt 2016, 23:08
Beitrag Re: Dichtmittelfragen untenrum..
Den Dichtring hab ich noch nie gewechselt. Und zum Abdichten untenrum (Ölschiene und -wanne) nehme ich Reinzosil schwarz.
So 23. Okt 2016, 12:34
Hi Guys,
I am in the process of changing the headgasket (saic) and oil rail and when dismantling the old oil rail I noticed that it was assembled without any sort of gasket, just plain aluminium on aluminium. I was under the impression that the oil rail had te be assembled using liquid gasket (I bought the recommended one from Rover) Why is it that the old one could be mounted without and the new one needs a gasket? Does anybody know?
regards
Alex
regards...
Alex
MGF 1.8; 2001
Lotus Elans S3SE big valve; 1967
Caterham Seven Cosworth 2.0 1988
Domino Pimlico; 1990
Aprilia Capo Nord ETV1000
(Nothing beats the smell of gasoline and burning rubber...)
Mo 10. Dez 2018, 14:03
Both types need a gasket as Mykel stated, liquid silicone based one.
But when dismantling there could be the impression no gasket has been used, because the very flat and smooth surfaces presses all the silicone out, so there will be no remarkable traces of them within the faces. So was it with my repair by changing the oilrail to the stronger one. After carefully inspection there was a thin film barely noticing after polluted with the rest of oil.
Or: It has been changed before without a gasket, bad idea in my mind.
Mo 10. Dez 2018, 17:02
Okay! I will not be pig-headed then and I will follow the rules.... Thank you!!
regards...
Alex
MGF 1.8; 2001
Mo 10. Dez 2018, 17:21
...and don`t block the oil-lines by applying to much of this pudding... :lol:
Mo 10. Dez 2018, 18:34
Hi mal ne dumme Frage aber die Oilrail selbst hat doch weder Dichtung noch Dichtmasse nötig ? Nur Die Ölwanne oder ??
Mo 10. Dez 2018, 21:49
falsch
um die Ölbohrungen in der Schiene gehört auch Flüssigdichtung
Mo 10. Dez 2018, 23:45
Durch die Oilrail fließt das Öl zu den Hauptlagern der Kurbelwelle, dann zu den Pleuellagern und letztendlich zu den Kolbenbolzen.
Die Dichtung verhindert Öldruckverlust.
Die Ölwanne selbst ist drucklos und dichet den Motor nach unten ab. Dieselbe Dichtmasse, die Mykel erwähnte, hab ich bei mir in beiden drin.
Mo 10. Dez 2018, 23:50
Man sollte aber keine Silikondichtmasse für die Ölschiene verwenden!!!
Sondern eher eine Anaerobe Dichtmasse die nur zwischen Metallen unter Luftausschluss aushärtet.!!!
Di 11. Dez 2018, 06:32
habe in 2006 beim HGF gleich die verstärkte Ölschiene mit eingebaut,
habe für die Ölschiene keinerlei Dichtmittel verwendet,
hatte bis zum Verkauf der Lady in 2017 keinerlei Probleme mit Öldruck oder Dergleichen!
Di 11. Dez 2018, 12:56
