Aktuelle Zeit: Mo 7. Sep 2026, 15:10
Spare rubber sleeves for igniton coils
Beitrag Spare rubber sleeves for igniton coils
As probably you have experienced the spark plugs rubber sleeves are very often quite impossible to be removed (pulling/twisting) without being destroyed.
Rover doesn't seel the rubber sleeve as a separate item, only with the complete ignition coil
An old Rover service guy told me that the Peugeot sleeves can be cut and fitted.
Have you experience on this issue ?
Shining sun this morning in Rome !
Sa 12. Dez 2009, 10:17
Beitrag Re: Spare rubber sleeves for igniton coils
Hi, for sure not :)
In deutsch: Die roten Gummitüllen an den Zündspulen (MKII und TF) gibt es nicht als Einzelteil.
Leider gehen die wohl bei häufigerer Montage/Demontage der Kerzen/Zündspulen kaputt.
Abhilfe/Tipp.
Die Teile vom Peugeot kann man abschneiden und dann passen die.
Wer's braucht ...
Sa 12. Dez 2009, 14:23
Hi Dieter,
thanks for your answer, do you know from which type of Peugeot engine we can swap the grommets.
I've just replaced the brake hoses with the braided ones from Goodridge and replaced all the brake fluid, there is a real effect on braking sensitivity.
Just bought new Ferodo DS performance pads, but I'll wait for installation.
Sa 12. Dez 2009, 14:49
