Aktuelle Zeit: Mo 21. Sep 2026, 01:54
IAT intake air temperature sensor not connected
Beitrag IAT intake air temperature sensor not connected
Today I was looking to replace the spark-plug (see another topic) I noticed the IAT sensor (installed on the cyl 4 intake duct near the fuel injector) is not connected.
I check for a loose plug, nothing.
The service manual explain that the MEMS use a default value.
I've already discovered that the engine bay alarm light is not connected to the MEMS ECU (pin 62 is empty)
My car is a TF MY2002 for EU market, I'm really questioning how Rover was working.
Do you think I can connect the IAT to the right MEMS pins, does it will work ? or the map has to be activated.
Mo 13. Jul 2009, 00:19
Mitglieder in diesem Forum: 0 Mitglieder und 72 Gäste
