Aktuelle Zeit: Mo 7. Sep 2026, 22:48
New dampers for TF
Beitrag New dampers for TF
Hi
I'd like to know which brand and type of shock absorbers you fitted to replace the original parts.
I'm looking to improve the comfort of my MY2002.
I was in touch with VHS, a group of people that have been in charge of cars handling dev for Rover until the company collaps, they sell a special set of Bilstein dampers (they have a website where they claim these dampers). I contacted Bilstein in order to know the pn of the Bilstein's dampers used in 2009/2010 TF, no way they wrote me to contact VHS. Once imported the 4 dampers will cost more than 600 €.
I contacted the italian co ORAL, they can provide special monotube gas dampers at 150€/pc.
I'm waitig for feedback from Monroe, the 2002/2004 dampers OEM supplier (I'm not sure they supplied the 2005 dampers for the last car with improved dampers)
The most common no OEM are Spax and Gax.
Has some one used Monroe or Bilstein or Koni for TF.
Thanks
Mi 22. Sep 2010, 23:43
Beitrag Re: New dampers for TF
I think you mean GAZ not GAX??
Have you see or hear from adjustable GAZ dampers?
I think with ajustable GAZ or with Spax dampers your wishes will be true.
regards klaus
Jetzt British Steel !!
Do 23. Sep 2010, 16:29
