| MGF Air Conditioning http://mgboard.de/viewtopic.php?f=19&t=3181 |
| Autor: | Kar-Solutions [ So 28. Feb 2010, 12:32 ] |
| Betreff des Beitrags: | MGF Air Conditioning |
Hi I have bought a kit of parts from a breaker to upgrade my car to Air Con. Can anyone tell me if the main front to rear compressor pipes run through the car or under the car? Dave K |
| Autor: | Dieter [ So 28. Feb 2010, 14:11 ] |
| Betreff des Beitrags: | Re: MGF Air Conditioning |
under the car parallel to the radiator pipes. I think you need to bolt off the reinforcement panel for easier access. Must get put back of course. But that's the easiest part |
| Autor: | Kar-Solutions [ So 28. Feb 2010, 14:20 ] |
Thanks Dieter. |
| Autor: | Kar-Solutions [ So 28. Feb 2010, 14:33 ] |
I think sorting out the wiring is going to be the most difficult part! |
| Autor: | Dieter [ So 28. Feb 2010, 14:54 ] |
yep I recall there where 2 of specific looms for the AC control. Switch etc and front dryer bottle. The main harness includes the wire for the compressor already at all MGF versions. ( connector behind the ECU leading to the other connector behind the fuse panel. ) |
