Aktuelle Zeit: Mi 1. Jul 2026, 18:25
MGF Air Conditioning
Beitrag MGF Air Conditioning
Hi I have bought a kit of parts from a breaker to upgrade my car to Air Con. Can anyone tell me if the main front to rear compressor pipes run through the car or under the car? Dave K
So 28. Feb 2010, 12:32
Beitrag Re: MGF Air Conditioning
under the car parallel to the radiator pipes. I think you need to bolt off the reinforcement panel for easier access. Must get put back of course. But that's the easiest part ;)
So 28. Feb 2010, 14:11
Thanks Dieter.
So 28. Feb 2010, 14:20
I think sorting out the wiring is going to be the most difficult part!
So 28. Feb 2010, 14:33
yep :angel:
I recall there where 2 of specific looms for the AC control. Switch etc and front dryer bottle.
The main harness includes the wire for the compressor already at all MGF versions. ( connector behind the ECU leading to the other connector behind the fuse panel. )
So 28. Feb 2010, 14:54
