Aktuelle Zeit: Mo 3. Jun 2024, 14:34
How to register !
Beitrag How to register !
Welcome on mgboard.de ! :up:
Please follow the steps below if you want to register with an English language interface:
1. Click "Registrieren" from the menu in the headlines
2. On the next page scroll down to the bottom, click "Ich bin mit diesen Bedingungen einverstanden"
3. Then the main registration page will appear. Look for the column "Sprache" where you can select "British English"
4. A new site with terms and conditions will automatically appear. You can agree at the bottom ;)
5. The rest of the registration is self-explanatory.
I hope that helps, in case of problems just ask :)
Gruß, Herbie
Mo 5. Jan 2009, 00:13
Beitrag Re: How to register !
Just to add help on how to switch to the English language option later, in case you got lost with the German Language option on the registration process:
  • Click on *Persönlicher Bereich* (User Control Panel)
  • Select *Einstellungen*, » Persönliche Einstellungen (Edit global Settings)
  • Select *British English*
See below
Di 6. Jan 2009, 00:22
as for the avatar, see below
Dateikommentar: go to User Control Panel
avatar.jpg [ 62.23 KiB | 25407-mal betrachtet ]
Fr 9. Jan 2009, 22:37
